T typle front end kit
What would cause a new fan clutch to remain engaged at all times?
Having done the 08 update "T" type linkage on a few trucks all I can add is when installed right Toe is set to 1/16-1/8" and forget it. Tires last longer and the trucks drive better. I had been looking into updating my 13 to the newest system until the recalls showed up on the drag link. I like the way the drag link connects to the passenger side steering knuckle. No flex in the cross over bar with the new system.
Can you please explain how it can be installed wrong?
Tie rod ends not being in the same plane causing binding or ball stud breakage. Toe in set wrong. Had a truck come in with 3/8” toe in from a tire shop’s free alignment . You could hear the tires scrubbing sideways as the truck drove into my shop.
