I took my truck in for 4 recalls, one of them being the #T05 SELECTIVE CATALYTIC REDUCTION replacement. On the way home, about 20 miles from the dealer, the check engine light came on. It was after hours when we picked it up, so we went on home, 70 miles each way. The next week we dropped it off on Thursday night, they called Friday and I believe he said the emission module had burned out, it wasn't covered by the recall, and I would have to pay for it. I told them to put the old SCR back on and remove the update because the truck wasn't broke and the light wasn't on when I brought it in. They said their manger wouldn't be in until Monday. Has anybody run into this?
Emission stuff should still be under warranty????
5. Emission Warranties RequiredBy Law
5.1 Federal Vehicle Emission Warranty -6.7L Diesel Equipped Heavy DutyTruck
A. Parts Covered for 5 Years or 50,000 Miles,Whichever Occurs First
Diesel equipped heavy duty trucks are 2500 and 3500models only.
Federal law requires Chrysler to warrant the following
emissions parts for 5 years or 50,000 miles, whichever occurs first.
• Air system controls;
• charge air cooler and associated plumbing;
• coolant temperature sensor;
• DEF system (includes tank, sensors, valves, pump,doser, control module and heater);
• engine speed, position sensor, and cam position sensor
• exhaust system (includes catalysts and sensors);
• electronic fuel injection system, including injector;
• exhaust manifold;
• exhaust gas recirculation valve and control system(includes EGR cooler);
• exhaust pipes (between exhaust manifold and lastcatalyst);
• fuel pump, fuel lines and fuel injectors;
• intake manifold;
• on-board diagnostic-system components;
• NOx sensors, Ammonia Sensor and associated modules;
• positive crankcase-ventilation (PCV) valve or orifice;
• powertrain control module;
• transmission-control module;
• turbocharger and turbocharger speed sensor;
• turbocharger compressor inlet air temperature/pressure sensor; and
• wiring harness circuits connected at both ends toemissions warrantable components.
B. Parts Covered for 8 Years or 80,000 Miles,Whichever Occurs First
If your truck has one of the following parts, this FederalEmission Warranty covers that part for a period of 8years or 80,000 miles,
whichever occurs first, calculatedfrom the start date of the Basic Limited Warranty as setforth in Section 2.1(E). The covered parts are:
• all catalysts
• transmission control module
