Tack wiring for 93
Rear wheel bearings
KDP question....
RSchwarzli
When wiring a tack into a 93 can you run off the existing wire that currently resides there or do you have to install the sensor and everything like you do on the 89/90's?
Secondly what is that wire that comes from the front of the engine?
Robert
The wire from the front of the engine is the RPM sensor.
On your 93 the tach wiring is factory installed. It is located under the dash around the left side of the steering column. It is a black plug with 4 wires in it.
