well, i had been planing on modding my tail lamps for a while now and this past weekend i finally did it. i had a pair of 55w off road type lights i got from the parts store when they were on sale for about 50% off [a good deal i think eh
] they have now become my backup lights.
the main reason i wanted to do the mod was to get amber colored turn signals. i like them more than red ones, and i feel they are more visiable than red ones when driving in traffic so it could be called a safety feature.
i cut and spliced the wires about 6" in from the tail lamp connector on both sides. the backup lamp, turn signal and brake wires were all snipped there. i spliced the brake signal wire into the brake light & turn signal wires, soldering them together and wrapping them in heat shrink. that gives me 2 brake light bulbs per side plus the center mounted one on the cap. i spliced the turn signal wire into the backup lamp wire to let me use amber colored bulbs where the backup lamps were, again, solder & heat shrink. . the pass. side backup lamp wire i just dead ended, and i just used the drivers side backup lamp signal to trigger the relay to turn on my new backup lights.
the backup lights are mounted to home made brackets made from 2" pieces of 1. 25" pipe with washers and nuts welded on either end for mounting [frame end - 3/4" washer with a 1/2" nut pressed into it, light end - 1/2" washer reamed out with a 3/8" nut pressed in it]. the mounts are bolted to the frame rails right at the end of them.
i ran a fused wire right from the drivers side battery down through the frame rail [drivers side]
i have some pictures of the mod, but i will get some night pictures soon
some pictures here
was the end result worth it? well i don't know for sure. it did give me several hours of quality time with the truck and it didn't cost too much.
only hitch i did run into was the pass. side wires were not the same color as the wiring diagram i printed out said it would be, but the pin positions are the same between the pass. side and drivers side.
some pictures here
