Tail shaft seal I thought?
NV5600 Breaking gears on the hwy
06 dodge 5.9 running real bad
I thought I had a tail shaft seal leak untill I pulled it apart and It wasnt leaking from the seal but was leaking from the center of the u joint.
What seals the end of the slip yoke?
Thanks Mitch
Nothing, best way to cure that is clean out the yoke real good (brake clean), then lay down a good deal of silicone into the end of it. Some will make a little cardboard disc also to squeeze in there, but mine have been fine with just the silicone . Once in a great while a spot weld is necessary to seal the hole up.
