Want to modify my tank/pick up module on my 2001 QC after installing a FASS so that FASS will run more efficiently.
How many bolts hold the bed on? I only see four ( two front that are attached to a bracket and two rear that run through the frame?).
After the fronts are removed and rear loosened I was gonna just tilt the front of the bed up with a floor jack and 2x4.
When removing the tank module my factory shop manual advises that the gasket needs to be replaced every time. Can this gasket be re-used? or can it be bought seperately?
Any other info will be greatly appreciated.
What else can be done to the module to make it flow better, other then remove the screen mesh on the intake?
J-
looking to do this on Tues.
J-
