Tare Weight CTD Rams ?
2500 pulling 10k 5th wheel. Will it do it?
Camper on the cover of Issue 33?
Hi All !
Wondering if there is anywhere on the net where there may be tare weight lisiting tables of the various CTD Rams ?
Had my 2WD 2500 Qaud Cab weighed at a local scale here and the print out shows 5226 lbs with driver and full fuel.
I don"t know the answer to your question but mine is how did your truck get so light? I have the same basic truck and weighed 6700 lbs, the only addition was the hitch. I would question the weighmaster, or maybe I should.
My 2wd weighs in at 6886 with the tank and driver both full of fuel (gas :eek: ). The only weight addition is the bed tool box that probably goes about 200 lbs. FAllen, you sound right at 1000 lbs light. You aren't running helium in your tires, are you :p ? Or a 2500 with a gas (gag) engine?
Heavy Ram?
My truck with all in the Sig and full tank and me in it weighs at 7630.
front axle was 4400lbs.
rear was 3230
I have a shell and tools and such
Tare Weights
Thanks very much for the info guys.
Looks like I better try a different scale here ! ! !
Also wonder how much heavier a 2500 Quad Cab 4x4 is, with the extra transfer case and differential, than the 2WD 2500?
