My TC has been doing the lock unlock for sometime now and unhooking the negative post has made it go away for up to two weeks after a 12 hr disconnect. Now it has to be for at least 24 hrs and only last a few hrs. Dave Goerend installed the noise filter and the tin foil wrap to no avail. It was much worse when his scan tool was on the truck. Now when the exhaust brake comes on the light in the controler box just flashes so the TC doesn't stay locked up. Does this sound like the PCM is going seeing as it is sensitive to the scan tool? I have used my truck a number of times to jumpstart equipment and was told this could have damaged the PCM. The APPS is also talked about for this issue but few that have replaced it have had success. Any help please! DW
