TDR Issue 75 - February/March/April 2012
TDR Issue 74 - November/December/January 2011-2012
TDR Issue 78 - November/December/January 2012-2013
TDRadmin
Staff Member
[RAW]#ad
<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="FONT-WEIGHT:bold">ARTICLES | Sold Out</span></font></td>
</tr>
<tr>
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">10 Back</span><br/>Issue 35 Review - February/March April 2002 • Industry News - Small Diesel Engines/Incorrect Reporting and Lube Oils • Feature Articles - The Turbo Diesel's Fuel Injection System/Bill Swail's Adventures/The Way We Were • Topics of Interest - That Sinking Feeling • Service Articles</span></td>
</tr>
<tr>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Member2Member</span><br/>Second Generation Fuel Level Sending Unit Repair • Replacement Front Seats • Replacement Front Seat (Part II) • Shock Absorber Replacement/Bilstein Shocks</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">First Generation</span><br/>Intermittent Engine Starting and Transmission Won't Go in Gear • Fuel Gauge and Low Fuel Light • Serpentine Belt Tracking Off Fan Pulley • Gear Case Locating Dowel, aka "Killer Dowel Pin, aka KDP • Grid Heater Relay • Hard To Start • Tow Ratings</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">12-Valve Engines</span><br/>Engine Oil Filters • Crankshaft Sensor • Engine Coolant Temperature Gauge • Crack in Door at Latch • Cruise Control Won't Hold Speed • Loose Fan Pulley • Engine Oil Pump • Engine Block Illustration • NV4500 Problem • Uprating the EGR 12-Valve Engine • Performance Re-Programming • EGT Difference Among Cylinders • Converting From Five-Speed to Six-Speed Transmission</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">24-Valve Engines</span><br/>Unidentified Part in the Transmission Pan • Overdrive Off • Dead Accelerator Pedal and Trouble Codes • Replace the Engine Block Heater • Harmonic Damper • Bosch 275 HP Injectors • Pressure Drop Across Fuel Filter </span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">5.9 HP CR</span><br/>Transmission Won't Shift Into or Stay in Park • Cruise Control Disengages Going Uphill • Radiator Removal Question • Remove and Replace the Engine Mounts • Injector Problems with Used Vegetable Oil as Fuel •Tires Versus Load Capacity</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">6.7 HP CR</span><br/>Diagnostic Trouble Code PO488 • J35 Recall (TSB18-024-09) Questions • EGR Service • Fuel Filter-Shell or No Shell • CCV Filter?</span></td>
</tr>
<tr>
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Fourth Generation</span><br/>Strange Ticking/Vibration • Key Fob Works Intermittently • Cab to Bed Seal and Possible Unintended Consequences • 68RFE Transmission Service • Air Conditioner Condenser Protection • How to Replace U-Joints</span></td>
</tr>
<tr>
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Your Story</span><br/>One Year Follow Up (2010 Ram ST)</span></td>
</tr>
<tr>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Technical Topics</span><br/>Options for Auxiliary Fuel Tanks, or How to Get Well-Tanked</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Blowin' In The Wind</span><br/>New Standards for Towing</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">TDReview</span><br/>Some Gotta Win - 3500 Evaluation (Dodge- Chevrolet - Ford)</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Motor Minded</span><br/>The Five Phases of D.I.Y. Learning</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Idle Clatter</span><br/>Fuel Filter Change Hints - 2010 and Up • Erratic Idle Speed</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Polly's Pickup</span><br/>Shopping For a Truck</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Have Ram, Will Travel</span><br/>Manual Transmission Rebuilds and Upgrades</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Back In The Saddle</span><br/>Replacing a Fuel Sending Unit • Carry a Big Stick...Colt Cams • MBRP = Exhausted</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">TDRV</span><br/>3.73 or 4.10 Axle Ratio?• Air Bags, Timbrens or None • Lubricating Trailer Wheel Bearings • Selecting Trailer Tires • First Tow With My "3500 Max Tow" Package</span></td>
</tr>
<tr align="left">
<td from="" the="" shop="" floor<br="">
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">From The Shop Floor</span><br/>No Start Tips</span></td>
</tr>
<tr align="left">
<td>
<span style="font-size:10pt;font-family:Arial;"><span style="font-weight:bold;">Exhaust Note by Kevin Cameron</span><br/>Simplicity and Something to Think About</span></td>
</tr>
</tbody>
</table>
<br style="COLOR:rgb(0,0,0)">[/RAW]
