Technical Engine Specifications
St. pipe vs. muffler
2003 Transfer Pumps
moonranch
Can anyone help? I am looking for some engine specifications for my '03 305hp CTD that I was not able to find in the Service Manual. Compression pressure when conducting a compression test; Connecting rod length; Head specs-including-intake and exhaust Valve size, intake and exhaust Port size/volume; Camshaft specs-including lift, duration, lobe seperation, lobe centerline, overlap; Rocker arm ratio, and any specs for the HX35-pressure ratio and CFM at peak efficiency.
Thank You
I would say Cummins would be your best bet for that info. DC just buys the motors. They have little or no idea what is actually under the valve cover. :)
