pwerwagn
I have a question I've wondered about for a long time that nobody has ever been able to answer. On a gas motor, running more fuel cools the combustion process, less fuel (or more air), otherwise known as lean, creates heat that can melt a piston. As we make more and more power with our diesels, it obviously requires more fuel and air. But why when we inject more fuel (i. e. larger injectors, fuel plate, fueling boxes, etc) do our EGT's increase instead of decrease as it would in a gasoline motor? I know that they run rich because of the smoke, and it seems like in general, the more smoke the higher EGT (that is a generalization, not true to every case, i know). Can anyone explain why they run hotter with more fuel and cooler with more air?
