Temp gauge problems
Keeping "Fog" Lites On
VA vs. Power Edge vs. Plug N Power vs..........
I need help!!! When I start my engine, for the first time, my temp gauge becomes irratic and I don't know what my engine temp is. After a few miles, the gauge settles down and seems to read ok. Could this be my sending unit, or the gauge itself. I had the thermostat replaced last year, and it just does not act like that is the problem. If it is the sending unit, what does one cost?
Randy Richmond, 98. 5 24 valve, 2500, 5 speed, 4x4, 3. 54, LB, QC, Van Aaken CPC, PacBrake, Walker flowthru muffler, Amsoil, running boards, Leer Shell, Metalic Red.
If the temp. is going higher than you think it should then leveling out, the thermostat may be at fault again. The original thermostats have a problem with a rubber cap coming loose on the valve part of the thermostat and blocking the water flow when the thermostat opens. BG
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Ranco 9000s, bug shield and window vents, black vented 5th wheel tailgate, aluminum tool box, 100 gal. aux. fuel tank not mounted yet.
Sounds like you have bad electrical connection to me. First place to look is on the sender,clean it up and put some anticorrosion goop on it.
[This message has been edited by illflem (edited 06-25-2000). ]
Randy the sending unit for the tempature gauge is located on the rear side of head drivers side. About 4 to 6 inches behind the fuel filter or last electrical part on the head. That where is located on 12 valves, but it seems to me that's where I saw it on my Freightliners 24 valve engine.
Missouri Mule 96 White 4X4 ST club cab,(grey int. ),5 spd, 3. 54 reg dif, 8 ft bed, 1 ft high cheater boards, front and side of bed,Pofile V bug shield,
99 Freight liner FL60 blue Cummins 24v 215 hp, 520 torgue,6 spd 3. 59 no spin rear, 16 ft dry box (white) 19. 5 low profile tires,Weight 11,000, gvw 23000, 11 to 12 mpg
Bill Thomas (Wild Bill)
The sending unit is at the front of engine on the left side near the thermostat housing/outlet radiator hose. It has a two wire connector plugged into it, one is black with light blue stripe, the other is tan with black stripe. The tan/black wire is the sending wire, the other is ground. bg
Thanks for the help guys. I guess I'll start with checking the connections, then if that doesn't fix it, the I'll replace the thermostat again. I hope it's not the sending unit. If it turns out to be the sending unit, what do they cost? Thanks.
