Engine/Transmission (1998.5 - 2002) temp gauge sensor
Howdy all, the same thing is happening to meeeeeeeeeeee!!!! :{ :{
I checked to see if the actual gauge went bad by pressing and holding the Tripmeter down while turning on the truck.
It worked.
So, Is there a part that I can replace to make the temperature gauge work??
A sensor of some sort?
Thanks for your time! Oo. :-laf
On my 01 the water temp sensor is in the front/top of the engine near where the radiator hose goes into the top of the block. Its a small sender that threads into the block and has two wires coming out of it.
Hope this helps
J-
Has it always only warmed up just above cold? If not mine did the same thing when the outside temp dropped. It was a broken thermostat, stuck partially open. Just another thought.
