Agades,
I don't think it's the VP.
I think that because you say the engine runs fine with the VP "hotwired" but like crap when conected to the ECM.
The hotwired VP runs fine? Ok then the pump is fine!
You have to search somewhere else for the root of your problem.
If the VP was bad, then it would idle bad also hotwired... .
That's why they use the hotwire test! To find out if it's the pump or something else.
I would suggest to trace down the wires to pin 6&7 of the VP. The pump can suck up to 30 Amps. If any conection or wire isn't in top shape... What about the relay in the PDC?
Marco
Marco
