mymtnhauler
Mymtnhauler- Again, power plants CAN run on ANYTHING!!! We CAN/DO generate power from clean sources. It comes down to choice and often (all too often) the easy and cheap way is to pollute. If 80% of electric generated is from coal then it is because it is cheap and easy. I'm sure you can think of other things that are cheap and easy and just as unhealthy. But as far as parts in an electric, all it takes is smart engineering, less weight =less inertia =less power to go and stop and collide with so less parts needed to do that. a 4wd really only needs 1 brake perhaps at the tailshaft/tranfercase. watch a monster truck race and count the brakes, only two, and I bet theres a bit of weight there too.
Adding a ( tailshaft or transfercase ) is more parts, and weight! For an electric with one motor to perform like a gas car that motor would have to be large and vary heavy! That is why the ( smart ENGINEERING ) is too put one lite motor at each wheel, there again is more moving parts to maintain, and would still need four or more brake assemblies; despite the ability to dienamicly brake with the motors! Not to mention these components need to be lubricated with something! And NO power plants can not run on ANYTHING, unless they are converted to use something other than there original fuel source and that would take years to convert just one plant! Yes we do have solar and wind, but to get that cost affective and available for all is still one or more decades in th future!
