Engine/Transmission (1998.5 - 2002) Thanks to Tim Barber and DTT
Engine/Transmission (1998.5 - 2002) engine stumbles under load
I'd like to second that thankyou,to Tim Barber
transmission is holding strong Tim. To thoughs of you who need performance work ,consider Tim Barber.
I got the billet input shaft, torque converter, valve body, and all internal frictions and steels with the new trans. Shifts great, very solid and firm. Ran 200 miles back to Alexandria from Norfolk right after the install. I know the power is getting to the ground.
Tim Barber is a great trans builder. If you are thinkin of a DTT in the VA/MD/PA/NC area, Tim is the man to do the job. Call DTT and they will get you in touch with Tim.
Thanks again to all.
Sleepy Creek
WOW! There's a DTT installer in Norfolk? That's nice to know. You mentioned performance work. Does he also do timing? If so, what's his contact info. Thanks, Mike
Tim does do performance work also. He has an awesome '00 Ram with twin turbos that really stickes you in your seat.
Try -- email address removed --
Tell him Jed gave you the info.
