I had the vibes (search 70mph vibrations), this is an old topic. Some trucks had this from factory, and there is not single absolute cure.
I replaced all the ujoints... didn't help. I replaced the front driveshaft (removing the driveshaft caused it to stop)... didn't help. Had the rear driveshaft balanced (it took a lot of weight), and while it was smoother; the underlying vibration was still there.
I finally purchased a Free-Spin kit from dynatrac... vibrations gone.
I have heard that it is resonant/compound vibrations, and curing one of the vibrating components will cure the vibrations.
I have read where a Dodge dealer "realigned" the drivetrain in the chassis (as in realligned the engine/transmission in the mounts) with some sucess... they were rumored to have bought trucks with the issue from other dealers, fixed and then resold them.
I have also noticed that some of those with the vibrations have had catastrophic failure of the tcase... I have read of at least two instances of this. This isn't saying the vibrations mean a failing tcase, or that they are even related... but both instances the owners reported having the vibrations prior to failure.
I have always assumed it was a bad machined part in the tcase, as it is a highspeed driveline vibration and seems connected to the components forward of the front tcase output. At least in my case. And since pulling the front shaft stopped only the front output from rotating (differential still turning), that's where I assumed the problem was located. However, I have also read where the dealers have replaced all the driveline components (transmission, transfercase, driveshafts, front/rear differentials) and never solved the problem.
There are a lot of threads about these vibrations on this forum...
