Originally posted by yogibear
I'm hoping with ddII's, I will have enough more hp to leave in 6th and #4, and keep right on trking. I may get myself right back in trouble again with the II's, but I'm going to find out. Let me know what any of you think out there.
Larry
Hey yogi, i have found in my truck, that the injectors seem to add a lot less heat for the same power than the box. With stock injectors and the box set to level 9, the power feels comparable to me as when i have the dd3's in and box off. however the egts get way higher with the box than the injectors. I think you may find with the bigger injectors, you may be able to have the same hp with the box on a lower setting, and a lot less egt's. My geuss is it has something to do with the injectors adding a larger amount of fuel throughout the spray cycle, whereas the box simple adds the fuel longer contributing to the egts
