The best oil for a 6.7(and all others)
Fuel Filter Replacement
Anybody tried bolting a Silver Bullet charger to a 6.7?
i have been reading articles and post on TDR for years about all the good oils. im not going to bad mouth the ones you guys think are great. however i have owned a large consruction company for years. the best oil to use is DA oil. they have oil made for your specfic need. they also have free oil sampling. check out there website and ask your Amsoil rep how is oil Compares with DA oil. we have used this oil for about 20 years. it has all been on extended drain intervals and we have had great luck with it. they have a new oil out just for all the new EPA engines.
Brian
www.dalube.com
(there website seems to have went down today, if the link doesnt work wait few hours and try it. it will be worth it) i tried to paste a PDF file below of the oil that would be best for the 6. 7
Reliant J-4 TM
Product Description
D-A Reliant™J-4 has been designed specifically to meet the stringent requirements of API Service
Category CJ-4 used in 2007 and later model diesel engines running primarily on ultra low sulphur
fuel and NOx reduction technology. Reliant J-4 is a technologically-advanced heavy-duty diesel
engine oil, designed to provide extra protection against deposits and wear for engines operating in
heavy duty service. Reliant J-4 is recommended for diesel engines requiring an engine oil meeting
API Service Categories CJ-4, CI-4+, CI-4, CH-4, CG-4, and CF. It is also suitable for modern gasoline
engines requiring API SM oil as well as older gasoline engines requiring SL, SJ and SH. Having
passed all tests on the first run, Reliant J-4 meets the requirements for Cat ECF-2 and ECF-3;
Cummins 20081; DDC 93K218; Mack EO-O Premium Plus ‘07; Mack EO-N Premium Plus '03;
Volvo VDS-4; MAN 3275; EMA DHD-1; and ACEA E7. Innovative concepts have been incorporated
into D-A Reliant J-4 to provide efficient equipment operation and improved component durability.
Product Features and Benefits
Carefully selected base oils designed for diesel engine service provide:
- reduced oil consumption
- improved control of engine wear through rapid oil flow on cold starts
- proper metal-to-metal separation during high temperature / high load operation.
Contains high dosage of active diesel detergents to keep internal engine parts clean
and operating efficiently under Exhaust Gas Recirculation conditions.
Meets service requirements of mixed heavy-duty diesel fleets in addition to meeting the oil
specifications for 2007 and later model diesel engines running on ultra low sulphur
diesel fuel.
API SM approval satisfies gasoline engine service requirements.
Resistance to in-service viscosity loss provides excellent viscosity protection under tough
service conditions. Reduces operating costs.
Precise product balance for optimum performance for reduced maintenance expense
and compliance with engine manufacturer warranty service requirements.
Reliant J-4 composition has been designed to provide extended life for exhaust aftertreatment
Lung, I had a trucking company for years and used DA oil also. I always sent in samples when I did oil changes. Once they called me at 9:00 PM. to tell me I had a trace of antifreeze in the oil. Its a long story but they saved a 3406 cat, engine for me. I've been retired for a few years and forgot about them, I think I'll give them a call. Thanks
Tim
