TravisG said:Jim, if anyone can do it Brent can.![]()
The reason I ask is when I'm on boost(15-20) mine spools to 80 so quick it's sick and I have blown a 40 yet.
Jim
Yooper1 said:If you want the cleanest set up... ... .
Diesel Freak said:... ... then titanium takes over... ...
CRoth - BD-Power said:Yup it was prety neat, the seoncd compressor wheel was made from Ti. The only problem is that turbine needed to generate huge amount of HP to turn the two compressors.
Diesel Freak said:now back to the topic at hand.
I would have to say that the "best" twin turbo setup would give the widest possible powerband and supply enough air to burn a given ammount of fuel without exceeding the current federal limits for Soot and NOx which are 4. 0g/BHPxHR and . 1g/BHPxHR respectively while at the same time keeping EGT at a "usefull" level.
NOx is the toughn one!!!!
Hohn said:Yes, but isn't the total turbine power LESS than it is in a twins setup with two turbines driving their own compressors?
