Well this year my truck is set up a little different than last year, Edge Comp and DD2's. Last year I had BD's PNP 2. Again with the colder weather the truck has the shudder back under light to moderate load with the comp on. When the comp is off the shudder is either gone or or so slight I can't feal it. I already checked the voltage at the pump wire, I have BD's pump cover, and the voltage is good, and I also tried dielectric grease on all the connction to the comp with no luck. Last year I got a new PNP under waranty and I never had a problem again. My brother-in-law now has my old PNP and his truck is fine.
Also the fuel pressure gauge has a slight bounce that matches the pulses of the shudder. Is anyone else back in the same boat?
