Is your CTD a Third gen? My heat exchanger is actually the OEM automatic heat exchanger for an auto equipped truck. The radiator for 03 through 09 trucks are the same for auto or manual, so the heat exchanger will clip on it. I can give you all the part numbers, if you PM me. This is what I'd install now if I were to do it again.Thank you very much for taking the time in showing this info. What is the item number for the heat exchanger?
Ralph
I only run mine when my temps get over 180*. I use a manual switch I installed on my dash that lights up when in the on position, so I don't forget it's on. However it does have a built in bypass, because the heat exchanger is an OEM part that has it already built in.Nicely done gentlemen....any need for a bypass in the winter?
https://www.dieselperformance.com/s...ission-cooler-kit-universial-1-2in-tubing-583
Read this thread I linked, for good info on my temps as I tested it when I finished it, it will give you most of the info your looking for. The BD cooler is what I'd go with for a 4th Gen. The last post has the part numbers. https://www.turbodieselregister.com...ooler?highlight=G56+transmission+temperaturesThank you very much for taking the time in showing this info. What is the item number for the heat exchanger?
Ralph
My guess is that what you will find is that pulling a load at highway speed in 6th gear (say 20k +) will send the trans temp over 240*. That was my experience.
"I ever get a rig that heavy, I'd seriously consider additional cooling, but rig, fully loaded is maybe 13K total, not exactly the hardest work for the truck at this point, but I'll have a better read with the temp gauge hooked up to know for sure." QUOTE]
You might be surprised once you get your gauge at how hot it gets even at that. Mine towing my empty dump trailer at about the total weight you are talking about will hit 240* at 70 mph on level ground in about 90 miles. It's just a slow steady climb. The higher it gets, the slower it climbs. The good news is that it did top out around there. Driving empty to Atlanta (from Central FL) with no trailer, it would get to about 230 ish but would take about 2.5 hours. This was all in about 90-93* weather. That was running about 74 mph. My guess is that the Fastcoolers will help very little but will slow the rise in temperature. I kind of figure the transmission is one big aluminum piece anyway so it is going to transfer heat about the same.
On my 06' Automatic, the Mag-Hytec double deep pan did make a little bit of difference and it certainly slowed the rise in temp a bunch. It did seem to lower operating temperature about 10-15 degrees towing (only time you could really tell on peak temp) but I attribute that more to the added depth getting the fins more into a colder air stream not near the engine or the exhaust. So there is some theory and some real world results I can attest too. Your experience may be different. Always cool to see and hear other's theories and experiences either way!
Are you aware your not supposed to tow in sixth gear, that will attribute to your overheating, even on flat running? For me, any grade I come to, I go to 5th until I've crested the summit. Back to unloaded temperatures, at 15K GCW my trans hit 250*+ with a 90* ambient.Good point, if I ever get a rig that heavy, I'd seriously consider additional cooling, but rig, fully loaded is maybe 13K total, not exactly the hardest work for the truck at this point, but I'll have a better read with the temp gauge hooked up to know for sure. What I can know with the FAST-Coolers alone, I have added fluid, and heat transfer area for cooling over what the OEM figured was needed.. but we do know there are ways to improve upon the OEM minimums for sure!
I've heard tail that you aren't supposed to tow in 6th and no disrespect intended because I truly want to know, where did you read this? I have owner's manuals for my 96', 04' 06', and my 16'. I can't find anywhere where it says not to tow in 6th in any of them. Besides, that simply isn't possible with today's interstate speeds. That being said, in slow rolling hills (north Florida, North Georgia before the mountains, rolling flats of the Carolinas) I try to stay in 6th most of the time but any serious hill, I downshift before I even have to put my foot on the floor. Typically speaking, I won't put it on the floor in 6th for more than about 5 seconds under any circumstances and I won't let the RPM's go below about 1700 ish in 6th except in coast.
