After 4 days Cummins Southern Plains called and said they can not leagally work on my truck because of the "hot rod" parts on it. The service writer did say they diagnosed the problem as a short in the wiring to the lift pump. Problem is the lift pump is running when the truck won't start. If the lift pump was shorting out, it wouldn't be running.
I can't figure it out. I know where the wiring problem is. I don't know if I can fix it short of replacing the whole harness (the problem is in the truck's harness, not in the pigtail off the pump). We'll see.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, Ranchhand bumpers, DeeZee toolbox, "Physcotty Air", TST PowerMax2, VA, 275's, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake, Cowl Induction Hood
"If it ain't broke, it ain't a Dodge"
