Mark Is Gonna like me for this post
Originally posted by Marco
There is no real damage to the engine with smoke( other then soot in the oil). Also a little smoke is inherent with the diesel combustion.
The real damage you do with BIG SMOKE is to the combustion. Inefficient injection, or too much fuel for the air charge in the cylinder, both harm the combustion. What you see then is smoke. In the case most of us are interested in, it harms HP.
Ok, that's cool, I was concerned that way overfueling could 'cause hot spots in the cylinders and pistons that wouldn't show up on a EGT Gauge.
Example: Going down the road at 1200* EGT Pre-Turbo, could there be hot spots that could 'cause Engine Damage even though the overall EGT is "Safe" ?
What I think about this first section is this,,,, Correct me if I'm in Left Field. .
If you have Huge, Shower Head Injectors, but can't get enough air in your truck... That it is a possibility if you stepped down to a smaller injector you could burn more of the fuel, and more HP Could be possible ? Or atleast Efficiancy would come way up ?
From this limit-point on, as we further increase fuel (load) we'll obtain always more smoke.
Marco,, I guess in Italy this is a bad thing?
But In reality I haven't Experianced BIG Smoke. Here comes Muncie though.
What happens? The engine isn't capable to burn all the fuel we're injecting. The smoke we see is oxidized but unburned fuel.
Inside the combustion chamber the excess fuel cools the burning flame thus it "absorbs" part of the combustion energy, which we wanted to translate into Hp.
In our imaginary engine test, we've gained 1 hp for every fuel-load increase. From the "inefficient combustion point" on for every fuel increase we'll see 1/3 Hp increase. As we go further with the fuelling we'll see the HP decrease.
I think what Marco is saying is that the motor in his example needs a B-1 turbo with the Big Exhaust Housing.
Excellent post Marco. I see all the stuff you are saying about efficiancy and smoke, etc. This what what your ECM's are all about.
But then to think that a guy like me would buy your High HP Re-ProgRAMmed Smokeless ECM, and then put a heavy fueling box on it.
To keep the thread slightly on topic,,
Is it possible to take a VP44 apart,,, and then RE-Assemble it? If so, if you had a few pennies you could have a high quailty machine shop bore out the plunger cylinders, and make bigger plungers.
The Curious,
Merrick Cummings Jr
