OK... So I am trying to figure out the best scenario to fix my poor fuel pressure problem. I recently (under warranty) had my VP44 and Lift pump replaced at 62K miles. They replaced the original lift pump with the in-tank setup. I installed half of the Vulcan big line kit (replaced the banjos on the VP44 and the Fuel Filter housing and installed a big line between the two) and put in a westach fuel pressure guage shortly after the dealer did the installation.
With the intank setup on a stock truck, I am getting 8psi at idle and can pull it down to almost 0psi at WOT. So after reading, reading, and more reading there is a pretty good consenscous that anything lower than 5psi at WOT could put the VP44 at risk of failure. Way to go Dodge!! Good job with that in-tank setup - NOT!
With a new VP44 installed, I would like to prolong its life as long as possible. So you hear things like FASS, RASP, Relocation kits, bigger lines, cam replacements with mechanical pumps, and so on. Which one to chose? mmmm... That is the question! As with all of us, we want a solution that works... ... ..... period. Yes money is an issue at times, but for me I just want the thing to work like the 12 Valves did. I feel the fuel system in our trucks is like 1 year old baby that never grows up. It needs constant attention, monitoring, and feedings (pressure) to survive. I am tempted to sell the truck and buy a 12valve again, but "I think" I am determined to get this right.
So here are my questions for you all:
1. I am thinking of running the in-tank setup along with adding the carter pump back to the original location. Do any of you have this setup? If so, has it been a reliable one for you so far? What kind of pressure are you getting with both pumps running?
1a. This question is a subset of question 1. I cannot find a "definitive" answer on whether to much fuel pressure will hurt the VP44. I found some that say it is fine, and others says it will hurt the internal seals. I could not find an answer on the web from bosch, but does anyone have any supporting documentation or experience that to much pressure will damage the VP44? I am thinking that both pumps working together may put out 25psi or more at idle.
I am fairly certain that the scenario above (running 2 pumps) will ultimately fail again. But how long is the question? If it will last close to 100k, I would be happy with that scenario. But I am not to sure.
2. Based on my reseach and opinions, I believe that going back to a mechanical fuel pump is the best option. That leaves 2 options - RASP and Cam Replacement. The RASP seems to be a good option and an option I may consider. I like that fact that I can set the pressure to what ever I prefer. The cam replacement option is a little extreme for me. I do like the option alot, but I can't rationalize replacing a perfectly good cam to fix a poorly designed fuel system. For those of you using the RASP setup, how many miles have you gotten out of it? Has it be fairly trouble free?
What would I do without TDR? Be lonely I guess.
Thanks Guys!
Thanks Guys!
