thanks
I didn't get a service manual for my truck yet. When I got it (the truck), I didn't even get an owner's manual with it. It was six months old and the first owner took the manual, the spare tire, and even the button that goes in the little compartment for a garage door opener
! Anyway, 110 ft lbs was a semi-educated guess. I didn't want to go too high without knowing what it should be. Guess I could have called the dealer to ask or posted a question on these forums
. Thanks illflem and Thomas for that bit of information, I'll be re-torquing my lugs tomorrow.
Also, I forgot to mention in my earlier post that torque sequence is equally, if not more important than torquing the lugs correctly. Most truck owners who do their own maintenance already know this, but for those who don't:
-----on six and eight bolt patterns: start with one, then go to the opposite. Now go to the next one beside the one you started with, then to its opposite... and so on, and so on.
-----on five bolt patterns: start with one, then go in a star shape around the lugs.
-----*ALSO*an alternate pattern for eight bolt: start with one then go to its opposite, now go to one 90 degrees either way, then go to its opposite, next go 45 degrees either way and then to its opposite, and finally 90 degrees again and to its opposite.
An important thing to remember is to go in steps while using a torque wrench. As I said in my earlier post, I usually go in 20-25 lb increments and then 10lbs for the last one.
Hope this helps someone.
-Ron
