Diesel's like heat.
I have been doing alot of pondering about this exact question. On the 2nd gen, the cooler 180* t-stat helped make a little more power and better throttle response, but only because it was "tricking" the ECM, and adding more timing and trying to heat the water up.
Side effects were poor A/C performance, and high auto transmission temps.
Your 3rd gen has a lock-up clutch for the cooling fan. If you lower your water temp the fan will rarely be engaged, making oil temps higher, trans temps higher (auto) and poor a/c performance at low speeds.
Your cylinder temps will be lower too, which won't be good either. Even at factory temps we are having a hard time keeping cylinder temps high enough at low speed, and low loads.
When towing you also run into another dilema to the fact that, the t-stat will be full open by the time your fan starts to engage, increasing the risk for overheating.
If anything, I'd like to see a bigger radiator and bigger fan with water temps at 210*.
The higher your cylinder and water temps are the more efficient your motor will burn fuel. In most cases the compression goes up.
When I get my 3rd gen I will leave the cooling system stock and only put a small 8" electric fan to help low speed a/c performance.
My $. 02
Merrick
