Thermastat Question
Engine Bulid
transmission Tube leaking - Grommet?
I KNOW IN A GAS MOTOR IF YOU GO TO A 160 OR A 180 DEGREE THERMOSTAT IT HELPS , DOES THAT WORK TOO WITH DIESELS ?
MY RUNS AROUND 195 - 200 ALWAYS , I THOUGHT IF I COULD FIND A 160 IF I WOULD BE DOING THE ENGINE GOOD OR BAD ? :-laf
A couple of thoughts..... you haven't seen a 160 or 180 thermostat in a gas engine in 20 years..... they need the heat of 195 to keep the engine temp up for complete fuel burn... .
Our trucks have an idle problem already... . the fast idle built into the ECM is to turn the engine faster to cause more heat... ... because at idle... the engine cools off... . and with this... . other issues..... I personally wouldn't do a thing to the cooling system.....
i also have a 01 chevy 3500 with a 160 in it , i do alot of towing , my brother has a 03 ford 460 with a 180 in it bvecause he tows alot too , so they still make them and people still use them , just some thoughts for you
Diesel's like heat.
I have been doing alot of pondering about this exact question. On the 2nd gen, the cooler 180* t-stat helped make a little more power and better throttle response, but only because it was "tricking" the ECM, and adding more timing and trying to heat the water up.
Side effects were poor A/C performance, and high auto transmission temps.
Your 3rd gen has a lock-up clutch for the cooling fan. If you lower your water temp the fan will rarely be engaged, making oil temps higher, trans temps higher (auto) and poor a/c performance at low speeds.
Your cylinder temps will be lower too, which won't be good either. Even at factory temps we are having a hard time keeping cylinder temps high enough at low speed, and low loads.
When towing you also run into another dilema to the fact that, the t-stat will be full open by the time your fan starts to engage, increasing the risk for overheating.
If anything, I'd like to see a bigger radiator and bigger fan with water temps at 210*.
The higher your cylinder and water temps are the more efficient your motor will burn fuel. In most cases the compression goes up.
When I get my 3rd gen I will leave the cooling system stock and only put a small 8" electric fan to help low speed a/c performance.
My $. 02
Merrick
In a GAS motor the only HELP a 160 or 180 thermostat does is on a computer controled EFI motor is to make it THINK its running cooler to make the mixture RICHER. On a HOT day the FINAL HIGH TEMP will be the same if it runs 200 degrees it will run 200 degrees with a 180 or 190 degree etc. Its just takes it LONGER to get here. On cold/cooler days it will run cooler. Eaither way to me its NO HELP. It screws with the mixture/computer parameters etc. A diesel is a like a furnace or fire place. Need a certain amount of heat to burn completely.
I'll just second what everyone else already said. Like Nick, I'd like to get a 200* thermostat if one was available. More heat = more efficiency.
-Ryan
Dont the 3rd gen trucks have the torque managment system that wont full fuel till the engine hits a set temp? Im guessin 160 is low. I think I would rather see it run a little warmer to help in carbon burn off and stuff like that.
After having the plastic cap of my '93 Dakota's radiator depart this mortal coil, the radiator guy told me to put a 180 degree thermostat in it. I did, and then it ran at 180 instead of 210. I noticed no performance or mileage issues - it still hauled butt and got 17 mpg.
Whether that translates to Cummins, I don't know. :)
Lamar
