Thanks for all the response guys.
I do have a quality aftermarket alarm, there is a blinking blue LED on the A-pillar, it did go off, honking the horn also. They had to have been in and out in seconds, pried the center dash cover off, damaging the dash cap and the center section, yanked the radio out, cut a few wires and yanked the rest due to seeing connectors pulled apart. Didn't touch another thing in the truck. They got what they were after. Sad for them, the head unit will not work without the brains that are hidden.
Here are my thoughts, minimize damage to the truck doors next time. Been to JimmieJammers web site, ordered a full set. In addition, I am crafting an aluminum overlay to go over the door handle, to keep them from getting in next time. Or at least cause them to tear up the diamond plate instead of my door. It will be harder to Jimmie, the alarm will be sounding, hopefully enough harder to get in to deter them.
Here is the kicker, I found a smoke machine. As soon as the alarm goes off, this fogger fills the entire cab with smoke at a very high velocity. That alone should deter them. If they do get in, they would have to open both doors and clear the smoke, something I do not believe they will take the time to do. I lke the thought of this deterrent.
So, my thought it to minimize damage next time, try to keep them from getting the door open, if they do, deter them. That way I keep mine what is mine.
What was my first thought? As soon as they get in and pop the center dash open, I squirt amonia in their face from behind the dash, also from the a-pillar. A tank, pump and solution with distribution hoses and outlets could be easily installed. Unfortunately, if they are breaking into my truck and I hurt them, I go to jail, go figure. I even thought of mounting a taser at the back of the cab on the roof to hit them in the back of the head as soon as they pop the dash. As you can tell, I am still pretty upset over this.
By the way, the smoke generator creates dense smoke, actually a fog that will not damage even sensitive electronics, so no damage to the truck, just keeps them from entering.
What do you all think?
Dave
