While testing an 03 Dodge Cummins 555 HO all stock except for a Banks 4" exhaust we learned that the Defueling was active during our dyno testing and reduced power below average numbers.
How we learned this, Our intention was to grab a base line run then test the Van Aaken C3 Pressure box installed but in off position, then in level 1 then in level 2.
To our surprise the Truck produced a much flatter torque curve with the Van Aaken plugged in but turned off indicating that just the addition of a 4" free flowing exhaust is enough to cause higher boost causing defueling.
The Van Aaken does Boost fooling even in the off position so the computer could not see the higher boost produced by the exhaust system.
So without boost fooling you are actually loosing power with a High flow exhaust due to defueling.
The Dyno plot below shows the difference in torque and Hp before and after the Van Aaken C3 install with switch in OFF positon.
