Things we learned on Dyno & 03 555 HO
questions, exhaust/intake
tsb for launch shudder; Understanding driveshaft angles
rbattelle said:
Ah HA! DLeno and HasselBach make good sense. So then I was right originally... TCluff's equation implies increasing backpressure would increase mean effective pressure, which means you'd make more power with a more restrictive exhaust?
[The fact that cylinder pressure equalizes to boost pressure is so obvious it never occurred to me. :rolleyes: ]
-Ryan
Sort of. You can increase torque at a low rpm, but once you transition into high rpm, you need good airflow to produce hp.
-Ryan
i never said restriction in the exhaust side produces power, i too did not bring the lobe overlap into the equation, i am sorry for the confusing info as you can tell, it can mean a lot of different things :-{}
