The controller activates lockup depending on speed, not which gear. The lowest speed is about 20 mph so I think I can get lockup in first gear if my foot stays on floor. This isn't something I’ve tried yet but I will. Up shifts while locked up feel about as natural as you could wish for, not harsh but firm and solid.
As for the downshifts when locked, yes it will downshift from OD to 3rd but I have to put my foot all the way to the floor to make it happen. When it does this shift, it's a very solid shift and it doesn't feel like it's doing any damage, which I expected it to. I'm not sure but there may be some linkage adjustments that could change the WOT requirement for OD to 3rd shifts. It doesn't bother me and I like everything about how the transmission performs so I’ll leave it as is.
When I’m in OD with the TC locked, if I turn OD off the TC will unlock for a second or two but only long enough for the transmission to shift. Does that make sense? Any time I use the OD switch on the dash, the controller unlocks the TC for a second.
I should add here that when the controller is going into TC lock up (at whatever speed I’ve set it at), a bright LED comes on and I hear a faint click from the controller box, like an electronic switch, and then a second or so later I feel the TC lock up. This time delay is the same delay I get when I turn OD off with the TC locked up. At first I didn’t like the delay but now I find it quite natural and it’s almost like an advanced warning that something is going happen and I have enough time to change the setting or ease up on the pedal if I don’t want to loose any rubber. (WOT)
Compared to stock? Sorry, no comparison at all. Next time your out and about find a stop light on a slight up hill grade. When the light turns green, take your foot off the brake, don’t touch the go pedal and notice what happens. Either you’ll sit where you stopped or creep backwards. Sound accurate? Doing the same thing with the ATS TC you’ll actually begin to move forward and be able to idle up to 15-20 mph! It’ll actually shift into second gear without touching the pedal. Now this doesn’t happen fast, it takes 10-15 seconds but the fact that it happens was really cool at first and I had to change my driving habits somewhat in parking lots and such. It’s similar to driving a gasser. At higher speeds it feels like I have better power transfer without the TC being locked up. No numbers to prove anything here, it just feels like I’m putting more power to the ground and this is especially noticeable with a load. Pulling away from stoplights with a load I don’t need to put the pedal ¾ of the way to the floor to get the truck to move. In fact, I only need a bit more pedal loaded than I need unloaded. (I’m referring to just normal take offs, not trying to beat the Asian atrocity in the next lane with a 10K+ loaded truck)
Does this answer your questions?
Brian
