With the 3. 73, you just drop one more gear and you get the same effect while braking. All 4. 10 gears do is give you better launch power and shortens up the shift drops, otherwise with 6 gears, it's easy to achieve the same RPM's as the 4. 10 by running one gear lower. I routinely haul in the range of 30,000 gcvw and when I do, I set the chip to stock to avoid over doing it on the drive train.
Thanx Uncle Harvey!
That answers the rest of my questions. Guess my next truck will only have 2 pedals... ... ... ... ... . one for go and one for stop!
In the 6 speed automatic, in which gear does the torque converter start to lock up?
