Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Third gen wheels on first gens?
putting a nv5600 in a 92 3500 daully
Hey BGilbert!
Howdy fellas,i normally post in the 3g forum,but had a question that you may be able to answer. Has anyone put the 3g 17" wheels on a 1st gen truck?Stud spacing the same? Etc. Thanks,Mark.
I like the idea, but dont think it'll work- something about the coin fit on first Gens, and the later ones not being. Then there is the one being hub centered, and the other being something else. BUt this is daullies; SRWs may not be a problem.
Daniel
wheels
they fit ,sort of. i have a set of 03 steel 17"s on my 93 d-250. back spacing is different. need to run 1" spacers to stop them from rubbing on the upper a arms and the inner fenderwell of the bed.
also 03 uses a 9/16 acorn lug and the center/hubcap clips to the edge of the lug. 93 uses 1/2 lug/stud
