Yeah those new armored HMMWV's with the 6. 5 turbo are so heavy there just as slow as the 6. 2 HMMWV's or a Volkswagon Bug!!!!!
J ueckert said:well,i guess i will be the one to step up and take a beating. 1, im told and have read that hummers came with three speed auto trannys and no od,they also had 4. 56 gear axle ratos,question how fast can a person expect a vehicle with no od and those low gears to run? under those circumstances a 5. 9 wouldnt run that fast. 2 if a sub with a 6. 2 and a banks turbo wouldnt pull a 12k trailer faster than 45mph somethings wrong. it had 3. 08 gears or swayed bad or had a mechanic working on it that didnt know what the hell he was doing,something was wrong! 3 to the guy that mentioned he had a 6. 5 thats been rebuilt twice with less than 50 k on it,what happend to it that required it to need such a premature rebuild?who is your mechanic? not to be rude,but you might need to find another one. i have owned several 6. 2,6. 5 diesels over the years,still got most of them,no in many cases they are not the engine that a ford or dodge diesel is,when it comes to daily heavy duty work,but the 6. 2 engines are tough little engines. i have also rebuilt many of these engines,many with 300k plus on them,most showed very little bearing wear,or cylinder wear. i have 2 ,3/4 ton trucks with 6. 2 engines, and manual trannys. one has 3. 73 gears the other has 4. 10 gears. both will tow a 10k fithwheel camper,same weight in cows or round bales of hay down the interstate doing the posted speed limit with no problems,only the long hills will knock them back to the 55 or 60 mph mark,in fact the truck with 3. 73 gears has a banks turbo on it,it will cruise 70 mph with a 12k trailer on it all day long,362k miles and i finaly put a new engine in it last year. my dads 93 6. 5 has 176k on it,other than a water pump and a auto transmission,the truck has not been touched mechanicly otherwise,the truck pulls heavy loads weekly also,however it does not tow quite as well as my turbo 6. 2... this post is not intended to be a flame,just stateing my personal experiances with these engines... ...
J ueckert said:3 to the guy that mentioned he had a 6. 5 thats been rebuilt twice with less than 50 k on it,what happend to it that required it to need such a premature rebuild?who is your mechanic? not to be rude,but you might need to find another one. i have owned several 6. 2,6. 5 diesels over the years,still got most of them,no in many cases they are not the engine that a ford or dodge diesel is,when it comes to daily heavy duty work,but the 6. 2 engines are tough little engines... ...
DPelletier said:OK, My turn;
- My 6. 5 was rebuilt both times by the local GM Dealership. The truck tows regularly, but less than 5,000 lbs and mostly highway driving. Both rebuilds were top-end rebuilds required due to bent valves/pushrods. I was told that the PLASTIC pces that hold the rocker arms straight broke off causing the damage. In addition, I have had the truck in to three different shops to deal with cold starting issues in the past three months. Many replaced parts and the pce of xxxx will still not start at -10 without plugging it in even if it was plugged in all night before going to the jobsite.
My truck was just picked up from the Dealer this morning after its latest efforts to reduce my wealth; In my hand I have a bill for $4,646. 27 to replace the dragging starter (lists for $605. 00) and the duel mass flywheel which came apart and took out the clutch, flywheel, and input shaft on the transmission. Fairly common apparently.
The 6. 2 may be reliable (albeit gutless as hell), but the 6. 5TD is the biggest turd of a diesel I have ever seen. I've spent around $20,000 dollars on this truck in the last 4 years and each time I fix something, I think OK, it should be good now. This is the last straw. Truck is for sale. I can lease another new Dodge Cummins for less than this turdmobile costs me in repairs.
Oh, yeah, it currently has 197,377 miles on it.
Dave
J ueckert said:pelletier if you think the 6. 5 was the biggest turd diesel,then you should have owned a 5. 7 in a work truck.
