fog light install
Purchased the "kit" from mopar, included new head light switch to activate, wiring "pig tails", and the inserts for the lights. not a bad price. removed lovered inserts from behind with a kinda of turn and push motion, came right out. factory fog lamps mounted right to the brackets and have all kinds of adjustment, (up/down, right left). put the new inserts in, driver side from behind, puleed it in and twisted until caught on the tab, passenger side got ahead of myself and installed fog lamp before insert and had to install insert from the front, a little harder took a couple of trys but do-able.
brighter lights could be had by changing bulbs, (did that on my old 99 3500). factory fog lamps "just the right size for the opening" so if purchasing an oem, need to check on size, (bigger lenses are a waste because of where they are mounted. also really liked the idea of not doing any wiring, except plugging in the pig tails to the factory installed wires that are on all the trucks weather or not fog lamps are ordered. also not drilling and mounting switch on new dash board, just pull on head light switch!
only down side reall large wattage lamps could melt factory wires!:--)
