J. R. Adkins - I have a slide-in camper that weights in at about 2600 lbs. I also have a 35-foot 5th wheel (12000 lbs. ), haven't towed it yet, but will soon.
On the camper, I played with different gears. I also have an auxiliary transmission set-up as an under drive (3. :54 or 4:10).
I do have the 370's. I guess I am having problem with having the HP, without being able to use it.
JohnE - I wonder how different 5 spd is compared to the auto? As verified HP, with those configurations, I am encouraged.
As for the bigger injectors giving more power through the entire rpm band, my dyno sheet supports that. I went from 1800 RPM to 2050 RPM shows 246 HP. At about 3150 RPM, it drops to about 220 HP. On speed, the chart shows 248. 6 HP from 46 MPH to about 75 MPH. I might add, the dyno guy would not go over 1200 degrees.
I think it was dynoed in 4th OD. It was in the 3:54 gear auxiliary Trans gear.
I have no idea as to the difference between a HX and HY turbo.
JJW-ND - The dyno numbers you have experienced are comparable to those of Johns.
I am not sure I am willing to go more than 16 degrees just yet.
Wayne
