Today while pulling my trailer (ofccourse it has to happen while towing) I noticed the truck wouldn't return all the way to idle. It would stop at about 1200 rpms. I'd goose the throttle alil like you would to take it off high idle and it came back down to the right idle speed. drove a few more miles before I had to let off the throttle again. did the same thing except held at about 1500 rpms. Every time I let off the throttle it got worse and worse.
As of now when in park or neutral the truck wants to idle about 2300 rpms. In gear (doesn't matter which one 1,2,3, or 4) it wants to run about 1900 rpms. The truck accelerates by itself upto about 1900 rpms then slowly (I mean real slowly) drops down but never below 1500 rpms.
I checked all the cables over. The cruise control cable seems to have some slack in it and the cable running from the pedal to the pump is tight. But where the cable meets the pedal the cable just stays put and the pedal slides along the cable I can get out pop the hood and move the lever on the side of the pump and it well return to idle and stay there until I hit the throttle again. It seems the cable is being held or something not allowing it to return to idle.
Am I on the right track thinking it's either the throttle cable or cruise cable. Oh the cruise cable was replaced 2 yrs ago when I bought the truck because it was broke.
TIA
Nathan
TIA
Nathan
