Decided to check to see where the missing spring connected & checked WOT. With the pedal to the floor, you can go in by hand & get another 1/2" of travel out of the linkage. If you reach back to the back side of the pump & twist the linkage that pivots in the middle, I still have 1/2" of travel in the bar.
I then loosened the adjusters in the 'kinked' bar & took out the slack. Now idle is way high.
I just adjusted it back the way it was.
It doesn't seem right. Shouldn't pedal to the floor take out all the slack in the linkage?
