I have had this problem for a while, but now it is getting worse. I saw some other threads like this, but their problems didn't seem to match mine. Here is what happens:
1 Cruising light throttle, (usually) about 55 in lockup.
2 Warm days, with A/C on( not sure if it matters)
3 Push pedal to speed up, like if the 55 zone changes to a 65, the pedal will act like nothing happened, and will stay at that power setting. I can move the pedal up and down, without any reaction, but if i floor it or let it idle for a sec, it goes away and she takes off like a bat out of you know where. Here's the problem, I have a quickcheck on this, and the map and iat sensors read normal, as well as the tps reading. I had a passenger look at the qc the first couple times it did it, and she said the numbers in throttle % changed, but the mighty cummins just motored along with a mind of it's own.
4 No codes
5 No smoke or rough running, ever.
Thanks for the help.
Nick
4 No codes
Nick
