I am about to service the automatic transmissions on our '92-93 service trucks and have some questions. Do any of yall know the best procedure to check/adjust the "bands" on the auto/od transmission? Also, is there a way to test/adjust the throttle position sensor that controls 4th gear on these transmissions? One of our '92 models (350, 2wd, auto/od, 3. 54) "hunts" between 3rd and 4th and sometimes won't even go into 4th. The transmission shifts fine other than the 3-4/4-3 thing. We keep the oil changed regularly and I adjusted the bands on one transmission before, but want to make sure it is properly done while we have the pan off. They have between 80,000 and 140,000 miles and have been serviced with OEM filters and Amsoil ATF oil. Thanks for any help you may be able to offer!
John
John
