Archived Throttle position sensor
Archived Rear pinion seal on Dana 80 0n 2500 4x4
Archived (Survey) Would you buy this truck?
Mike the TPS is located on the side of the throttle body.
If you want I can fax you the page out of the service manuel
The TPS for your truck is a ATP and it is on the left side of the engine near the front under the black plastic cover. It is factory preset and not supposed to be adjusted in the field, they are very expensive and covered under your engine warranty.
