Anyone had experience setting the TP switch? Mine got out of position earlier in the year, caused several uncommanded downshifts from OD to 3rd. Had it set at a garage, although it seems set too soft. Any acceleration <50 mph and it will down shift, re engaging cruise will cause it to happen, even when running empty. At speeds >50 mph OD will stay engaged and acceleration is normal.
Thanks in advance.
Ian.
'93 D250 ext. cab. Upgraded injectors, 3. 5" exhaust, K & N filter, Xmsn oil cooler and fan, 4 gauge mount, mirror tubes reversed, RACOR fuel filter, larger transmission oil pan.
Thanks in advance.
Ian.
