When driving in 3rd gear with O/D button in or out, transmission will act like it shifts into neutral, engine revs up and truck slows down. Had to put transmission into neutral then back into drive to get it to operate normally. This happened under light throttle after hitting a bump in the road. When driving in 3rd gear with O/D button in or out, transmission will start acting like it’s up shifting and down shifting rather violently. Need to depress O/D button to solve problem . This occurs around 50mph. I’m not sure if it’s shifting or if the engine is surging. I ran a search for throttle position sensor problems and came up empty. From what I remember about the post on TPS’s this act’s like a bad sensor. Any ideas, any fixes? Thanks, Jeff
