1995 2500, 4 x 4, 5 spd
The other day, after not haven driven the truck for a week, and we had the first morning in the low 20's, I started the engine with-out any problem, however, I could not press down on the throttle. I let it idle for a while, and tried the throttle again, but it was stuck. I pressed really hard, and I got myself a very cold engine with some very high RPM's! I quickly shut it down.
I waited till the next day, when the temp was about 40, and tried again. It started on the first try, AND, the throttle operated as it should. Drove the truck for a couple of days with-out any problems, then today, with the temp again in the low 20's, the throttle is stuck again.
I sprayed some WD-40 at the injection pump end of the cable without any effect. Where, or what else should I be looking at?
Tony
Tony
