Consider:
- it takes a finite amount of time for the initial fuel to begin evaporating, thus producing vapors that will burn
- as the fuel evaporates, it cools, thus reducing available heat, to some degree
The injection of fuel has to be timed so that a portion of the fuel has evaporated and started burning before TDC is reached. As long as the fuel-air mix is swirling around in the cylinder, the fuel will continue to evaporate and burn after TDC, thus maintaining high cylinder pressure even as the piston is dropping.
A 12V's standard injection timing is around 12 degrees BTC, which probably produces optimal operating conditions around 2000 RPM (and, of course, sub-optimal conditions around low idle and governed RPM). Consider if you have your fuel injected at 6 degrees BTC. The engine would run much quieter because ignition likely isn't happening until after TDC, and peak cylinder pressure is considerably lower. Remember, the usual way to reduce a 12V's NOx emissions is to retard the timing, to reduce peak cylinder pressure, which prevents NOx from forming. Of course, power is reduced as well.
Now consider if you have your fuel injected at 20 degrees BTC. If the charge air is cool (such as at little or no boost), the fuel won't evaporate rapidly, and idle operation may be quite similar to that at normal timing. But once boost increases, thus increasing the temperature of the compressing air in the cylinder, fuel will evaporate more quickly and burn sooner. The charge will be heating and expanding while the cylinder is still headed up to TDC.
Now think of what happens in a modified sled puller running 60 degrees of timing. They pretty much have to run reduced compression ratio so that the engine will idle: reduced compression allows fuel to be injected that early without reaching destructive cylinder pressure at idle (that is, ignition so early it tries to turn the engine backward). And as RPM increases on this engine, ignition begins to approach ideal conditions, but is still early, but is OK because the heat of compression is still tolerably low. When the engine is turning fast enough and enough fuel is being burned to light the turbos, ignition is nearly optimal. But the charge air out of the turbos is now too hot, and ignition begins to happen too early. Now they turn on the water injection to cool the charge air and increase the apparent compression ratio. It a combination of RPM, boost, water injection and injection timing that allows a sled pulling engine to generate such large HP without blowing up, because all the elements have been tuned and timed to produce ideal ignition at a specific RPM. Put differently, maximum torque and HP are achieved because all the elements that compression ignition rely on have been carefully balanced. Not enough water? Charge air is too hot and cylinder pressure could become destructively high. And power drops. Charge air is too cool? Ignition may well be delayed. And power drops. Similar things happen when any of the other variables change. Mechanically-injected pulling engines are a wonder of tuning.
This is one reason I still say that common rail engines with piezo injectors will eventually take over. Because it is so easy to vary injection timing on a CR motor, it will be relatively easy to produce a tune for whatever ambient conditions are found. It might even be possible to create a tune that checks all relevant parameters (charge temp, charge pressure, RPM, delta RPM, EGT, requested fueling versus actual RPM, cylinder pressure, block temp, head temp, coolant temp, oil temp, etc. ) and produces optimal torque and HP for the current application. At any RPM. For any injectable fuel.
Huge peak cylinder pressures usually happen because of very early ignition at an RPM. On many Cummins engines, the head gasket gives out first. On a few Duramaxes, rods and pistons have broken throwing the engine into auto preventative maintenace dissassembly mode.
Huge peak cylinder pressures also happen because nitrous is used without considering its effect on ignition timing: nitrous greatly increases the probability that O or O2 will be next to a fuel molecule that is hot enough to burn. This increased probability significantly advances ignition; injection timing must be retarded to compensate, so that ignition still happens at the best time.
As I said, things to ponder.
