Consider:The injection of fuel has to be timed so that a portion of the fuel has evaporated and started burning before TDC is reached. As long as the fuel-air mix is swirling around in the cylinder, the fuel will continue to evaporate and burn after TDC, thus maintaining high cylinder pressure even as the piston is dropping.
- it takes a finite amount of time for the initial fuel to begin evaporating, thus producing vapors that will burn
- as the fuel evaporates, it cools, thus reducing available heat, to some degree
Yeah OK this makes sense now. In a gas engine the fuel is almost completely vaporized at ignition and the vapor / air is almost fully mixed at the right ratio for combustion. So nearly all the fuel combusts almost instantly at ignition. Hence the dramatic pressure increase at ignition / combustion.
While in the the diesel engine the fuel is only atomized, not vaporized. Vaporization and combustion occur during the same time period. Hence the constant pressure at combustion, as it takes more time for process to occur. And in that regard the actual pressure in the cylinder probably controls the rate of vaporization / combustion. Then throw boost into the mixture with varying charge temperatures I can see how it gets complex to hit the timing exactly.
A 12V's standard injection timing is around 12 degrees BTC, which probably produces optimal operating conditions around 2000 RPM (and, of course, sub-optimal conditions around low idle and governed RPM). Consider if you have your fuel injected at 6 degrees BTC. The engine would run much quieter because ignition likely isn't happening until after TDC, and peak cylinder pressure is considerably lower. Remember, the usual way to reduce a 12V's NOx emissions is to retard the timing, to reduce peak cylinder pressure, which prevents NOx from forming. Of course, power is reduced as well.
I am thinking this is closer to OEM under NOx restrictions. The higher compression is at, at ignition then the higher the combustion temperature will be and the higher the NOx partition of exhaust gases would be.
And this is closer to a "electronically" tuned engine or a 12v at its "tuned" RPM. I could see how a CR could really hit it dead on, just like a electronically tuned fuel injected gas engine. And a VP44 engine could get pretty darn close, but not quite like a CR could over the whole RPM range.
On an electronically tuned engine the combustion pressure spike as illustrated above could be more or less an internet myth I think. I am talking about the over the counter style tuners for liability reasons on the part of the tuner manufacturer.
As I said, things to ponder.
Thanks for the wonderful insight;
Jim
