Timing and duration boxes
History of bad injector pumps
CP3 Pump
Are there any other timing, and duration boxes on the market beside the tst powermax cr. With all the new releases, ive been kinda behind on keeping up. I like low end power, but from what ive read, it seems like the pressure boxes are what enhances that?
I think VanAaken makes a duration box.
The Bully Dog Downloader does duration and there is a PPE box.
Also, the Edge Juice with attitude is out there now and available.
If you dont have gauges yet, you can save a little cash by getting the TST Cr with the digital gauges.
Both Duration and Pressure can wake up the bottom end depending on how it is programmed.
Typically though an Edge EZ or Ramifier stacked with a duration box like Edge Juice or TST will "wake it up" on the bottom side.
I'm sure this has been covered before, but.....
Everything I read says the '03'04 EZ is pressure only. The Edge website calls it a pressure/timing box ... ... ... . what gives?
Edge website said:
The Cummins motor is one of the most powerful motors ever put in a pickup truck. The Edge EZ module unleashes the potential of this monster by carefully monitoring RPM, timing, turbo boost pressure and fueling parameters and adjusting fueling and timing to maximize power, torque and driveability.
Edge EZ
The Edge EZ is only a pressure box.
JHardwick said:
So nobody has the real answer? Edge says timing, general census says pressure only :confused:
I believe doug found that the timing change was a side effect to the pressure, in other words the EZ cannot be programmed to give 30* of timing like a TRUE timing box -(not that you would want that)
