Little known fact..... When in a hurry and your trying to time your CTD using an inductive pickup and pop the gear loose... turn the engine over... . about the ammount you need... . hope the pump doesn't turn back... . bolt it back on and start... ...
A CTD will run but not idle with the timing set 60 degrees BEFORE TDC. :--) OOPS! Needless to say... the "quick easy way" turned into the normal dial indicator time consuming way.
I know I know... just do it right the first time..... but I just HAD to try!
Josh
Josh
