Timing? How to, check & set
help!!! 03 ho no rail pressure
Buying an '06, auto 2WD: what problems to look for?
Iam still having the knocking issues and just about to ? Blank, dont know what to do next? but for some reason I think it may have jumped time on me. And what makes me think this is I never in the past had the smoke that is coming out of the vent ( pcv ) like I have now?#@$%!#@$%!:{:{
You can't set the timing. It is controlled by the ECM. If you have a knock and blow by, chances are you melted a piston and scored a cylinder.
I agree with sag2. The knock could be from a bad piston in the bore or it is detonating the residual oil in that cylinder. A leak down test would be in order.
